ched
Established Member
I have a TV across 1 axis of the room and a projector on the other axis so only 1 in use at any time.
I have a Humax Aura freeview pvr that I want to be connected to the TV for daytime viewing, then in the evening I want it to be connected to the AV amp then to the projector.
So I think I need an HDMI mirror box so I don't need to swap cables around. I have 1 very cheapy HDMI mirror box that splits the AV amp output so I can watch HD DVD, Fire Stick, FreeSat box on either TV or Projector and that works fine but it's just 1080. The Aura is 4K on some apps and the TV displays that.
I have tried a basic HDMI mirror box (about £15 on amazon) but the Aura doesn't seem to like that and the projector won't 'sync', the amp doesn't seem to lock onto the signal either.
I could feed the Aura hdmi into the AV amp but it's an old amp so to save power it's on a smart plug and off in the day so I don't think it will pass through the Aura signal to the TV., plus amp wont do 4K.
Bottom line is there a budget box that will allow the Aura HDMI out (4k) to be fed to both the tv (4K) and the av amp-Projector (1080)? Worst case both running at 1080 would be OK.
Thanks for any help.
