Question Hdmi 2.0a
Discussion in 'Cables & Switches' started by Braska10, Apr 19, 2016.
Tags:
  1. Braska10
    Braska10
    Apr 17, 2007
    78
    Hello, I am trying to buy an HDMI 2.0a with a length of 20 meters. The tallest I could find is 5 meters. Any help would be appreciated.
  2. Member 581642
    Member 581642
    Jan 3, 2012
    11,106
    +2,501
    HDMI Cables do not have version numbers they are either standard , High Speed or new premium.
    No cable over 8M will be certified as High Speed.
    WHat are you connecting ?
  3. Braska10
    Braska10
    Apr 17, 2007
    78
    I will be connecting a 65" HDR TV with a PC. Thanks for the reply
  4. Member 581642
    Member 581642
    Jan 3, 2012
    11,106
    +2,501
    Are both the TV and the PC Graphic card HDMI 2.0 HDCP2.2 compliant ?
    What resolution and Frames per second are you looking to display ?
    I suggest getting a good quality 20m cable from a reputable seller, and trying it out, though depending on what you are wanting to send a HDBaseT HDMI over Cat5/6 extender would be a better more reliable option
  5. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    28,385
    The Borders
    +3,434
    At present it is nigh on impossible to provide an HDMI cable which consistently caters for 2160p, 60fps, HDR, 4.4.4 processing at anything longer than about 4m.
    HDBT in its current spec is not going to work.
    A Fibre optic cable is the only realistic option at this time - assuming you are willing to spend the required monies, we have a few in and working as required.
    As Seb says ignore HDMI Version numbers and remember that any claims of 18 Gbps or similar are not verifiable or repeatable to any known/agreed standard.
    HDMI.org have introduced the new 'Premium High Speed' certification program - not many cables around as yet and those I have seen are no longer than 8m.
    http://www.hdmi.org/manufacturer/premiumcable/Premium_HDMI_Cable_Certification_Program.aspx
    If you don't want to go fibre either move the kit closer together, accept the limitations of current cable technology or be ready to spend a frustrating few months trying to find a working solution out of the myriad cables purporting to be 4K ready at 20m.
    Joe
  6. Braska10
    Braska10
    Apr 17, 2007
    78
    Thanks for the reply, Yes both TV and the PC Graphic card will be HDMI 2.0 HDCP2.2 compliant.
    The optical fiber extender would be the best option, if it will keep the quality. Still I think I have to wait till 4k ones come out.
    Thanks again for your help
  7. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    28,385
    The Borders
    +3,434
    2160p,60 is possible with Fibre - 4.4.4 can still be tricky but the latest versions of some cables look like they will do the trick.
    Joe
  8. Braska10
    Braska10
    Apr 17, 2007
    78
    Now it depends also on the price... Maybe its more worth it to buy a 4k monitor also for the PC. Joe, could you please suggest me a good 20m Hdmi so at least I would have the best picture possible with a cable of that length.
  9. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    28,385
    The Borders
    +3,434
    20m sits in the middle of the the 'factory' terminated options we use - 60' (18.2m) is around £240 and 80' (24.3m) is around £290.
    A suitable 4k Display local to the PC is a good option - I have a Dell P2715Q bolted to my iMac (that was around £480).
    Joe
  10. Braska10
    Braska10
    Apr 17, 2007
    78
    Thanks a lot for your help
