Question HDMI 2.0a vs 2.0b switches for higher bit 4k PC formats?
Discussion in 'Cables & Switches' started by markm75, Mar 9, 2017.
  1. markm75
    markm75
    Oct 16, 2014
    28
    4
    Does anyone have a good grasp of HDMI 2.0a vs 2.0b in terms of supporting (eventual) higher bit formats like 4K 4:2:2 10bit which i think requires 18gbps throughput (which hdmi 2.0a cant handle?)
    I use DP 1.2 to hdmi 2.0 from my PC.
    I'm looking at getting a 3-6 port HDMI selector switch that is either hdmi 2.0a or 2.0b and cant decide which to go with.. either way they arent that pricey, under $100 as cheap as $42.
    This to bypass my onkyo 1030 receiver, which doesnt support 4k at 4:4:4 or even 4:2:2 nor hdr for passthrough..
    Of the hdmi switches these were my choices (there arent that many that are hdmi 2.0a or higher)..
    ***Smartooo 26041C Premium $89.99 4x1 HDMI 2.0b
    10bit HDR, CES support with 2.0b (or just enhanced CES?) ; 18gbps and 600mhz; HEVC H.265
    Can turn off autoswitch (a bonus)
    Huierav HDMI 2.0a 5 x 1
    $49.99
    (Same basic features as the 3 port below)
    ***Huierav 3 port $42.99 HDMI 2.0A
    **should be able to select a port that’s NOT active, though it does AUTO switch and cant turn off auto
    Lists 600mhz, so should be 18gbs (but contradicts HDMI 2.0a, i thought 600mhz was only hdmi 2.0b?)
    Any ideas on this.. i'm leaning towards the Smartooo, simply because its hdmi 2.0b, but maybe the 3 or 5 port Huierav is just as good and capable of even 4:2:2 10bit?
    Thoughts?
  2. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    28,383
    The Borders
    +3,433
