HDMI 2.0 > 1.3a compatibility with 1080P SDR output
Cosmic Pablo
Hi everyone,
I’m having a HDMI related technical question, and I figured some of the experts here could help.
My current A/V receiver is the Yamaha RX-V1800, which is HDMI 1.3a. I still works perfectly, and I want to update my blu-ray player. But all the current decent players feature a HDMI 2.0 video output…
So my question is:
Since HDMI is supposed to be background compatible, and if I only play blu-rays (therefore sticking to a 1080P SDR signal), will the RX-V1800 HDMI 1.3a input still be able to process a video signal coming from a HDMI 2.0 output ?
Thanks a lot,
JM
alebonau
Hi everyone,
So my question is:
Thanks a lot,
JM
will find the blu-ray player if its a panasonic will just dial back the output to 1080p and will get a message onscreen its doing that
alebonau
Thank you for your reply.
So if I only output a 1080P signal, it should work, right?
yep, even if outputting a 4k signal; eg in the pana it will just detect and swap back. a lot of folks do this where say they dont have a 4k uhd display but want to take advantage of often the 3D audio (atmos, dts-X) tracks these discs often have where blu-ray doesnt.
Pulse1
You won't get HDR or BT2020 either and the 4k resolution will be downscaled to 1080p. My advice would be just get an HD Blu-ray player and enjoy 1080p SDR Discs.
Cosmic Pablo
Thank you for the replies.
Unfortunately, good quality HD BD players only are all sold out now, which is why my only options are either a cheap player, or a BD / 4K one.
So I'll go with a BD / 4K one, if only to future proof my setup when I decide to update my receiver.
Thanks again!
alebonau
Thanks again!
probably a good thing for future anyways :) as you say so can upgrade around it later :)
