Question Hdmi 17.8Gbps Vs 18Gbps
Discussion in 'Cables & Switches' started by bp2411, Jul 21, 2018.
Tags:
  1. bp2411
    bp2411
    Dec 12, 2010
    707
    28
    Cardiff
    +73
    Hello everyone, I'm having trouble getting a signal from my Xbox one s when I set my Sony TV to enhanced hdmi mode. My hdmi leads are 17.8Gbps but Sony's website states I need 18Gbps, is it really that simple?
  2. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    28,917
    The Borders
    +3,569
    'My hdmi leads are 17.8Gbps' - in reality those figures mean very little.
    The only 'Certified' labelling for HDMI cables is from HDMI.org and those are Standard, High Speed, Premium High Speed and Ultra High Speed.
    HDMI :: Manufacturer :: HDMI 1.4 :: Finding the Right Cable
    How long is your installed cable - that is usually the crucial 'specification' with 4K UHD signals?
    Joe
  3. bp2411
    bp2411
    Dec 12, 2010
    707
    28
    Cardiff
    +73
  4. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    28,917
    The Borders
    +3,569
    HDMI cables - sometimes very short cables can cause some devices a problem.
    XB1S - try connecting it direct to the Sony TV and see if that works in terms of the image and the settings you are aiming for.
    Joe
  5. Abacus
    Abacus
    Jan 19, 2015
    747
    67
    Torbay
    +482
    Does your AVR support UHD at 18GBs?
    Bill
  6. bp2411
    bp2411
    Dec 12, 2010
    707
    28
    Cardiff
    +73
    I'll try connecting directly to the TV and report back, regarding the AVR I'm not sure if it supports uhd at 18Gbps and I can't find anything online about it. My Apple TV works fine though?
  7. bp2411
    bp2411
    Dec 12, 2010
    707
    28
    Cardiff
    +73
    I just tried using a different hdmi lead, same make & length but I'm unable to take the lead from the AVR straight to the TV so I had to use another lead. It worked fine, I then plugged the Xbox back into the AVR and that also worked. Am I looking at possibly a faulty hdmi lead?
  8. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    28,917
    The Borders
    +3,569
    HDMI cable - could be 'incompatible' rather than faulty.
    HPD (Hot Plug Detect) - sometimes making the 'direct' connection initiates the required handshake between the two devices and once they have made that initial handshake they are happy to get on with it on subsequent sessions even with a Repeater (your AVR) device in the signal path.
    Now it s working 'don't touch it' :)
    Joe
