New Patreon Tier and Early Access Content available. If you would like to support AVForums, we now have a new Patreon Tier which gives you access to selected news, reviews and articles before they are available to the public. Read more.
Hi, just want to know if anyone bought hdmi cables for 3D tv? Was looking at Wireworld Chroma 6 but everyone is saying all HDMI are the same, cheap or expensive.
There's no such thing as an HDMI 1.4 cable. HDMI 1.4 is a hardware and feature specification. Your options are High speed with/without ethernet or standard speed with/without ethernet. If you don't require ethernet then a high speed cable should properly support the mandatory 3D specs.
Use a credible source that specifies the cable in accordance with HDMI standards and can provide evidence of appropriate certification at the length your require. High quality certified cable doesn't need to be expensive.
