hddvd player net conection
Discussion in 'Blu-ray & DVD Players & Recorders' started by joepaint, Jan 23, 2008.
  1. joepaint
    joepaint
    Jan 20, 2007
    16
    Hi .Can anyone help me get the toshiba HD-E1 connected to the net. I have it wired into a router from virgin broadband modem. I have tried what the manual says but i get can't find server.:lease:
  2. kingfats
    kingfats
    Dec 29, 2006
    36,741
    Windsor
    +8,969
    Hi mate :)
    Sometimes it takes a few attempts to get things going ( took mine about five times to connect when i first got the Xe1) if it does not connect,power down and retry. :smashin:
    Also make sure:
    DHCP and DNS are on and Proxy settings to OFF. :)
  3. Hovvy
    Hovvy
    can you download these firmware updates onto a disc from tosh website and load them up.
  4. choddo2006
    choddo2006
    Dec 30, 2005
    8,528
    +542
  5. joepaint
    joepaint
    Jan 20, 2007
    16
    Hi Kingfat, I have tried what you said but still no luck. I cannot get connected to a ps3 either, says dns error.
  6. Dave2
    Dave2
    Sep 9, 2006
    3,965
    Newcastle Upon Tyne
    +529
    Your router need setting up , maybe try putting the ip assigned to your tosh in the DMZ
  7. joepaint
    joepaint
    Jan 20, 2007
    16
    hI. I have just had the router set up by a pro. At the time i asked him about the connection to the player and he said it should work, but he had no experience with hddvd download matters.
  8. jon1
    jon1
    Feb 4, 2006
    1,976
    out in the sticks
    +170
    Is it a wireless router?..if so then the ps3 should pick it up ..with the ps3 being wifi
    jon
  9. joepaint
    joepaint
    Jan 20, 2007
    16
    Hi Jon 2. Yes it is a wireless router,but i am useing a cable to connect to the ps3 and the toshiba just now.The trouble is i am getting similar messages saying can not find server. Thanks for your suggestion.
