HDDs?
Discussion in 'Computer Components' started by sarpal, Mar 26, 2006.
  1. sarpal
    sarpal
    Sep 23, 2005
    93
    +3
    Has anyone identified HDDs that are quiet and suitable for HTPCs? I'm looking to upgrade (or add) because the Samsung 80Gb SATA I'm using as the data disk "ticks" all the time (!)
    I know that PVRs use "CE" drives but that this may compromise speed etc, does anyone have any suggestions?
  2. Cable Monkey
    Cable Monkey
    Feb 10, 2002
    3,494
    Birmingham
    +205
    The Samsung Spinpoints are acknowledged as being amongst the quietest. You can also try isolation and silent enclosures to block out the last of that noise if yours is a spinpoint and you don't find it quiet enough.
  3. drummerjohn
    drummerjohn
    Sep 2, 2001
    2,497
    South Derbyshire
    +205
    Samsung all the way.
  4. Mr Mandrake
    Mr Mandrake
    I have Seagate Barracudas in my system (3 of them) in an Antec Sonata II case, and it's pretty quiet. It is designed to be a quiet case and the drives are mounted on rubber grommits though, so that may be significant.
    Simon
  5. sarpal
    sarpal
    Sep 23, 2005
    93
    +3
    Thanks all for the info (and link), I now know what to do!
