HDD Upgrade Questions
Discussion in 'Playstation Forums' started by hybridtheory, Jun 11, 2009.
  1. hybridtheory
    hybridtheory
    Mar 31, 2009
    6,247
    Antrim, Northern Ireland
    +388
    I've just upgraded my PS3 to a 320GB HDD, its a Western Digital Scorpio Blue 320GB. Went through the initial setup menus after formatting the HDD. Just checked the system information and beside free space it says, 263GB/298GB. To me that does sound right. Is there something I havent done or is this reading normal?
    Baz
  2. Axum
    Axum
    Aug 27, 2007
    6,139
    +805
    Normal, you've said yourself it sounds right :)
  3. kharma45
    kharma45
    Oct 31, 2007
    455
    28
    Londonderry/Derry
    +71
    It's perfectly normal, some of the missing space is taken by the PS3 OS.
  4. adbrad
    adbrad
    Dec 9, 2008
    618
    leicester
    +54
    Yes thats right. I got the same, for a start the 320gb is really about 300gb, for hardrive reasons. And the ps3 takes 10% of the size of the hardrive for the OS, which is about 30gb :eek:. I have no clue why, as it works fine without all that space.:mad:
