HDD to dvd
Discussion in 'Blu-ray & DVD Players & Recorders' started by WeirdFish, Dec 7, 2003.
  1. WeirdFish
    WeirdFish
    Jun 28, 2003
    881
    Hadleigh, Essex
    +15
    I was talking to a friend last night trying to convince him that nows as good as time as any to buy a dvd recorder, regardless of format, and he asked me a question about HDD recorders. I have sky+ so I didnt know, but I know a lot of people that probably do :D
    If you've recordered something onto a HDD and then want to back it up to dvd, does this happen in real time or is it a quick data transfer.
    When you back up sky+ you have to play back the program while recording it onto dvd, so it takes however long the program is. Is this the same with HDD/DVD recorders?
    Steve
  2. Yuccaman
    Yuccaman
    Mar 23, 2003
    101
    Wierdfish, Only recorders at the upper end of the market (Panasonic E100 and one or two more), will allow high speed dub onto DVD-R. With the E100, this can only be done if the recording on the HDD is transferred at the same encoding rate.
    Typically, with an HDD/DVD combo, it's best to record from the source (Sky+) to the HDD at the highest possible quality, before editing & dubbing to DVD-R using a slightly lower quality setting. After all, you only get 1 hour at best quality on a DVD-R, so more often that note, you'll be compromising between quality and amount of contents on a disc.
  3. kenfowler3966
    kenfowler3966
    Jul 23, 2001
    844
    19
    leeds UK
    +15
    Just leave the machine dubbing and go to work or to bed depending on the time of day, it doesnt matter then how long it takes.
  4. bobbles
    bobbles
    at the highest rate how long can you fit onto the hard disc 9hrs or so?
  5. pio5100h
    pio5100h
    Nov 30, 2003
    171
    +3
    - High speed dubbing (4X -R, 2X -RW) can also be performed by the pioneer 5100h (and 510H, 610H, 515H, 710H).
    Burning at full speed (-R) on the 5100h: max 15 minutes + max 2 minutes to finalize.
    - The panny E100 has a 80 and 120 GB HDD- model dependent, if I recall correctly.
    - At highest bitrate settings +- 10Mbps will get you 17.5 hours on a 80GB HDD (i.e. in FINE-XP mode).
    In SP mode -4.5 mbps- you get about 35 hours on a 80GB HDD.
    - Thus one the future Sony models, at that same bitrate (cause Sony will support one even higher maximum bitrate) with 320 GB HDD that would mean 70 hours in FINE/XP mode.
  6. bobbles
    bobbles
    yeah sorry I was thinking of the 40Gb HS2
  7. phelings
    phelings
    Jul 24, 2003
    1,025
    36
    The HS2 offers 9 hours at XP.It will also do high speed dubbing,but only using HDD-RAM,or vice versa
  8. WeirdFish
    WeirdFish
    Jun 28, 2003
    881
    Hadleigh, Essex
    +15
    Thanks.
