HDD to DVD copying - any difference ?
Discussion in 'Blu-ray & DVD Players & Recorders' started by bankroot, Jan 14, 2005.
  1. bankroot
    bankroot
    Jan 14, 2005
    61
    Hello everybody,
    I have a simple question.
    Lets assume I record a TV program (it takes 2 hours 20 mins) on HDD in as best as possible mode and 2 hr mode (I own Pioneer-520, in this box is called FINE and SP mode respectively).
    After that I would like to copy those materials on DVD disc in Optimized mode or manually choose the time of recording (MN19)
    Which copy will be better ? (depends on source quality)
    Why ?
    bankroot
  2. Rasczak
    Rasczak
    Apr 3, 2002
    21,700
    Warwick
    +2,578
    What you want to do is record onto the HDD in the nearest quality setting to the programmes length. That way you can high speed dub to the DVD-R without any loss of quality.
    If you record onto the HDD in Fine or SP and then re-encode dub to DVD-R you will effectively have a second generation copy and picture quality will be poorer.
  3. bankroot
    bankroot
    Jan 14, 2005
    61
    thank you for your answer Rasczak :)
    , but my question was: will be the same quality or different ?
    (I know will be poorer)
    greetings
    bankroot
  4. Rasczak
    Rasczak
    Apr 3, 2002
    21,700
    Warwick
    +2,578
    Recording onto the HDD in FINE and re-encoding to DVD-R to fit the disc will look slightly better than SP > DVD-R. However both will look significantly worse than calculating the end running time of the disc (i.e. 3 x 45mins) and using the nearest recording mode followed by high speed dub.
  5. bankroot
    bankroot
    Jan 14, 2005
    61
    thank you again, I have to change my approach to recording ;)
    bankroot
