HDD Recorder without DVD Recorder?
Discussion in 'Blu-ray & DVD Players & Recorders' started by cryocon, Sep 6, 2005.
  1. cryocon
    cryocon
    Ideally i would like a Freeview box with a built in HDD recorder, but sadly i live in an area where Freeview is unavailable yet. I therefore have Sky FTV, as i have just cancelled my contract due to not wanting to pay £20 for a couple of channels i don't watch. I have been looking round for a stand alone HDD recorder, but they all have a DVD recorder as well. I'm not bothered about backing up stuff to dvd as i will just be recording programs that i would miss if i am not in. Any other features like inputs for camcorders isn't important as i have my pc for that kind of stuff.
    There seems to be a gap in the market for a stand alone HDD recorder that can record from a satellite set top box. I don't want to spend a fortune on a recorder and have looked at the Lite-On ones, but they are so ugly. So to the question, does anyone know of a standalone HDD recorder without DVD recorder or can they recommend an alternative.
    thanks
  2. LV426
    LV426
    Administrator Staff Member
    Jul 14, 2000
    12,789
    Somewhere in South Yorkshire
    +4,984
    AFAIK, it has to be (in a non-Freeview area) either $ky+, or, as you've identified, a HDD-DVD machine (preferably, in your case, one with Set Top Box control like the Pioneer 530). However, no doubt someone will recommend the all-but-obsolete (in the UK) TiVo.
  3. cryocon
    cryocon
    I've just checked out the manual for the Pioneer 530 and unfortunately the EPG won't work for me as it grabs the data from Eurosport here in the UK and i don't have that channel.
    Anyone had any experience with the Phantom PVR with a Sky box?
  4. alan8477
    alan8477
    Dec 17, 2001
    574
    Pershore
    +5
    My Toshiba XS 34 controls my Sky box. I can input the Sky channel number in the timer and it will switch at the appropriate time. Has a 160GB HD.
  5. JayCee
    JayCee
    Jan 20, 2004
    20,067
    Lanarkshire
    +1,912
    That may be so but "cryocon" wants one without a DVD recorder.
  6. cryocon
    cryocon
    Looks like they don't exist though. I've just looked in Dixons and they have a Pioneer DVR-420 for £249, just reading reviews and going through the manual now to see if this is going to the one.
  7. alan8477
    alan8477
    Dec 17, 2001
    574
    Pershore
    +5
    Yawn....
  8. eddyad
    eddyad
    Jan 5, 2003
    940
    Hampshire
    +9
    On page 29 the 530 manual says download works from ITV analogue.
  9. cryocon
    cryocon
    But i'm going to be connecting it to my sky box so that won't work either.
  10. eddyad
    eddyad
    Jan 5, 2003
    940
    Hampshire
    +9
    There is no Eurosport on Freeview, but my understanding is that the ITV download carries the programme guide for the box/service you have, providing it is supported by GuidePlus.
    So Freeview box users get their digital guide (for compatible boxes) from ITV analogue - and assuming you have analogue TV available then you just plug the aerial through to the 530 .
    Check your sky box for compatibility on http://www.europe.guideplus.com/
    Click the Our Service tab and the receivers link is in paragraph 2.
    If your receiver is there and you set up a 530 correctly with the right box and using ITV it should work.
    I suppose the downloaded gude may contain all the Sky channels you dont have, but then if you tried to record one you'd get exactly what you get if you select it on your sky box for your TV - like my Freeview box has all the TopUp channels but I just get a mesage that says 'encrypted channel' if I choose one.
    I don't have the 530 (420 at present), but downloaded the manual, and this forum generally agrees with what I've said.
    Finally, if you don't have analogue you would still be able to use the 530 to control the sky box, but it would mean setting the timer manually instead of using the programme guide. Of course, the 530 would still need to 'know' which (compatible) sky box you have to get the IR signal right.
    In this case the Toshiba 34 would work the same way (it doesn't have GuidePlus).
    It may be useful if someone else would confirm all this :)
  11. Liam @ Prog AV
    Liam @ Prog AV
    Well-known Member AVForums Sponsor
    Oct 18, 2002
    8,498
    Kent
    +827
    THere are one or two as you rightly point out, but they are either pants or ugly as you also point out! You are so limited with choice you might as well just get one with a DVD burner in it to get the better recorder overall. I see a 160g device in Aldi for pittance over on the offers forum. So what if you won't use the DVD bit, with the way the market is saturated with DVD recording devices it probably costs a manufacturer more to NOT have a drive in it anyway lol!!!!
    Or TiVo - but no doubt you won't want to pay subs!
  12. shoehorn
    shoehorn
    Jul 2, 2003
    1,601
    The Garden of England
    +32
    How about an Archos (see here)
    I've got the AV4100 (the 7th one down) and it will do what you want (I think), it's also great for holidays!
    - video, Music and a storage device for all those digital pictures you want to take!
    the AV500 and AV700 look like they can do the same.
    Even the Mrs would recommend one! :thumbsup:
  13. eddyad
    eddyad
    Jan 5, 2003
    940
    Hampshire
    +9
    I've edited my post but it didn't move down the list.
  14. skyline32
    skyline32
    Aug 9, 2004
    75
    You might look out for someone who has a DVD/HDD recorder with a broken DVD drive - like myself for example, assuming I don't get any joy from Toshiba about replacing the drive in my 18-month old RD XS32.
  15. LV426
    LV426
    Jul 14, 2000
    12,789
    +4,984
    In fact, either Eurosport, or ITV's terrestrial analog transmissions. So provided you have terrestrial analog reception (and it would be rare if you didn't) then you have your EPG.
  16. cryocon
    cryocon
    Thanks for everyones replies. I've just got myself a Pioneer DVR420H, i know it's a bit old now and is going to be discontinued but for £250 i can't really argue. There seems to be quite a few different ways that it can be set up to record so i'll have to do a bit of experimenting.
    I couldn't really justify spending anymore than this as i only want it to record the odd program when i'm out. I could have actually just plugged my VCR back in.
