hdd problem pace v 2
Discussion in 'Satellite TV, Sky TV & FreeSat' started by dubledene, Apr 28, 2005.
  1. dubledene
    dubledene
    hi chaps recently upgraded my sky + box with a maxtor160gb 5400rpm 2 mb ata133d-max16 4r160lo, which died on me !!
    returned the hdd and got a replacement this morning put the drive in my box and i cant record and ive noticed that the signal 2 bit in the menus was blank!.
    so i did a reset then house keeping but to no avail so i put the old 40 gig original and hey presto everything works!! have i got a duff maxtor drive??
  2. johndon
    johndon
    Feb 3, 2002
    1,975
    63
    +108
    Possibly as one of the symptoms of loss of signal in input 2 is a duff HD.
    John
  3. dubledene
    dubledene
    ok put the hdd in my pc but when i go into "my computer " it aint there! bios sees it but i cant do any thing to it. the jumper is out as it says ( no jumper-slave) got a discette with the maxtor thing on it but cant find the hdd!!!!
