HDD on a budget
Discussion in 'Blu-ray & DVD Players & Recorders' started by waz2004, Dec 16, 2004.
  1. waz2004
    waz2004
    Sep 14, 2004
    295
    +6
    Can anyone recommend a hard disk drive and dvd recorder.
    main use will be backing up vhs tapes onto HDD then onto DVD
    the only other option is to go through the PC route.
    thanks
  2. waz2004
    waz2004
    Sep 14, 2004
    295
    +6
    yoohoo :clap: anyone there?
    i am not asking for a £200 or £800+ player, all i want is no-frills hdd ok :smashin:
  3. eddyad
    eddyad
    Jan 5, 2003
    940
    Hampshire
    +9
    Pioneer is a make that has a specific VCR (VHS) input setting. (You set the mode by input socket). There are 6 input picture quality presets:
    Tuner – suitable for general TV broadcasts
    VCR – suitable for video cassettes
    LDP – suitable for Laserdiscs
    plus 3 user settings.
    I don't know how the first three differ, but I suppose it's something to do with noise reduction and the different characteristics of the signals from the various sources.
    So my suggestion would be to look for a Pioneer 420 around £350.
    When copying from VHS you won't need to do better than LP mode on HDD/DVD, that's around 4 hours per DVD.
    There are diagrams for wiring with a VCR in the Pioneer manual. Thee is also a set of front sockets if both the rear scarts are in use.
    The input presets are described on page 95.
    You can download the manual from www.pioneer.co.uk
