HDD HD Camcorder question
Discussion in 'Camcorders, Action Cams & Video Making Forum' started by robfosters, Sep 12, 2007.
  1. robfosters
    robfosters
    Feb 8, 2007
    2,146
    +217
    Thinking of getting one of these as they look great.
    One question, can you do minor edits on the camera, and do you have to go through a PC or can you plug an external DVD recorder straight into it.
    I would imagine you cant because of the burning software and so on. It's just a general query really.
  2. redsox_mark
    redsox_mark
    Oct 20, 2003
    6,512
    Bath, England
    +620
    Yes, you can edit on the camcorder - delete clips, split clips (then delete the bit you don't want), etc.
    If you mean by external DVD recorder an external PC drive (e.g. connected by USB), no you can't connect direct to that without a PC. You can connect to a "set top" DVD recorder, but only in SD mode (there aren't yet any high def settop DVD recorders).
  3. robfosters
    robfosters
    Feb 8, 2007
    2,146
    +217
    And do these HD camcorders really look HD when played through a good HD telly?
  4. senu
    senu
    Aug 26, 2005
    19,349
    Denham, South Bucks
    +2,811
    That is when they look really good.
    The wow factor .
    why do you think otherwise?:confused:
  5. redsox_mark
    redsox_mark
    Oct 20, 2003
    6,512
    Bath, England
    +620
    Yes they look really good... providing the lighting is decent! (Like any camcorder they perform better in decent light... and the high def makes this even more noticable).
  6. robfosters
    robfosters
    Feb 8, 2007
    2,146
    +217
    I dont know really. It's just that I did'nt really think that you could get sort of quality from a 1k camcorder.
