HDD+Divx+USB?
Discussion in 'Blu-ray & DVD Players & Recorders' started by shweeney, Jan 2, 2007.
  1. shweeney
    shweeney
    Jan 2, 2007
    7
    can anyone recommend a recorder with the following features
    HDD (not too pushed whether it has DVDR as well)
    Divx
    USB-to-HDD copying
    ie - basically a media centre that also records
    I've looked at the Yamada, Ellion and LiteOn models but they all seem to have significant flaws - are there any other options?
  2. concrete monkey
    concrete monkey
    Dec 31, 2006
    60
    what about the pioneer 640h or the 545h!
    there a bit pricey but you have to pay for quality!
  3. shweeney
    shweeney
    Jan 2, 2007
    7
    afaik the pioneer doesn't allow you to copy or view DIVX via the USB port.
  4. concrete monkey
    concrete monkey
    Dec 31, 2006
    60
    i think your stumped then!
    sounds like the mpaa and the riaa have been dictating what these companys can and cant do!
    and what we can and cant do with our machines! ....i hate them greedy so and so's
  5. countryman
    countryman
    Mar 5, 2005
    +12
    Shweeney,
    I picked up a Samsung DVD-HR738 from Comet last week which does what you asked for. It has 250Gb at £299 but there is also a DVD-HR733 with 80Gb around £200 on the net.
    Both have USB 2.0 which I have used to copy mp3 and Divx files to & from the Recorder plus play directly from the USB device. USB should also work with external hard drives which I will try as soon as my Western Digital arrives.
    My DVD-HR738 has HDMI at only 576p BUT it still delivers great pictures and greaty improves Sky+.
    I've had it one week and so far very happy with what it promised. Only niggle so far is it seems picky with recordable DVDs.
    I would definitely recommend it.
  6. shweeney
    shweeney
    Jan 2, 2007
    7
    thanks - looks like a good box, but a bit too rich for my blood....
    notice there also a cheaper HR734 (160GB), but it has no USB :(
  7. ajm007
    ajm007
    Apr 29, 2006
    384
    +8
    Which one and what were the reasons for not going for it?
    The reason i ask is i have the 1000hx and it does have the features you ask for but the usb port is only usb 1. so transfer speeds are a little slow.
