HDCP on screenplay 5000, nothing
Discussion in 'Projectors, Screens & Video Processors' started by shanebuss, Jul 12, 2005.
  1. shanebuss
    shanebuss
    I have a infocus SP 5000. I love it minus one thing, I cannot get the DVI w/HDCP working.
    I when I connect the M1-DVI cable to my PC, it works fine. When I connect it to an HDCP source like my motorola cable box, or my samsung HD841 dvd player, i get nothing.
    I'm wondering if it could be the cable, but since it works fine with my PC DVI i'm unsure. I bought the cable on ebay, not from INFOCUS.
    Anyone else had these issues?
    Thanks,
    Shane
  2. PJTX100
    PJTX100
    Dec 21, 2004
    8,134
    +564
    Have you told the DVD player to output to DVI rather than, say, component or s-vid? Menu option IIRC...PJ :)
  3. shanebuss
    shanebuss
    yes i did. same thing with the comcast box.
  4. PJTX100
    PJTX100
    Dec 21, 2004
    8,134
    +564
    I think the 5000 is HDCP compliant so it shouldn't be that.
    The Samsung's MR hack removes HDCP - it does on the 745 and other models anyway. Is yours hacked?...PJ :)
  5. shanebuss
    shanebuss
    no its not.. i'll have to look into that. thanks for the tip
  6. Geoxis
    Geoxis
    Apr 4, 2005
    312
    Surrey
    +15
    How is the 5000 image with DVDs?
  7. shanebuss
    shanebuss
    looks great. i have been using an HTCP with ffdshow.
    really happy with the projector minus i cant get any HDCP stuff to work. tonight i will disable hdcp on the samsung and see how it goes
  8. Geoxis
    Geoxis
    Apr 4, 2005
    312
    Surrey
    +15
    Do you have any shots of the picture?
  9. shanebuss
    shanebuss
    nope, sure dont. i had a ben q 7220 before that (1024x768) and it blows that out of the water.
