HDCD Playback
Discussion in 'AV Receivers & Amplifiers' started by nickoff, Jan 22, 2001.
  1. nickoff
    nickoff
    Do you require a receiver with HDCD playback capabilities or do you just require a CD or DVD player that can pass HDCD signal?
    As you can see, I'm confused....
  2. ReTrO
    ReTrO
    Jul 12, 2000
    3,507
    2
    71
    High Wycombe, Bucks, UK
    +59
    HDCD works on the priciple that somewhere in the player there is a chip that will 'decode' the normal 44.1khz 16bit data into (I think) 20bit data. This is done inside the player as far as I know, as there are no HDCD compatable digital amps etc.
    This means you will need a stereo phono connection to hear the difference, I think.
    Anyone know anything else?
    Rick
    'I am just a figment of your imagination.'
    Work Site: The Sound Gallery
    Home Site: WD A.V.
