HDBaseT with LAN Setup Advice
Discussion in 'Cables & Switches' started by sellers75, Sep 22, 2015.
  1. sellers75
    sellers75
    Sep 22, 2015
    5
    4
    England
    Hi All,
    Apologies if this has been covered elsewhere, however I can't find a complete answer and really need some advice as I'm very new to this and don't want to spank a load of money then get it wrong...
    I'm having the house refurbished and hence want to create a distributed AV solution whilst the whole place is getting re-wired. I've seen a few options in terms of HDBaseT solutions from CYP, Wyrestorm, HDAnywhere etc. BUT, I also want a remote KVM solution so that I can have my PC Tower at Node Zero, whilst having the Keyboard, Monitor, Mouse, Speakers etc etc elsewhere (purely for a neat looking solution, the KVM is in the kitchen...).
    Basically, what's the best way to wire it? I have media files on a NAS, we also use Smart TV services like Netflix. I have a PS3 but assume any solution that puts a PS3 in Node 0 is clunky due to the Bluetooth thing... Could the PC Tower be plumbed directly into the HDBaseT device then viewed anywhere? I also understand that the remote HDBaseT units have LAN distributed via the Ethernet ports... Does this just mean I can plug anything into it and access the internet?
    Finally I do some PC gaming so I'm looking for low latency in this respect... See attached my pure guess at a network diagram (looking at it now I guess I wouldn't connect the NAS to the switch and the HDBaseT unit but hey ho, not editing it now!). Not sure if I need a switch at all but what do you think!? Thanks very much!
    [​IMG]
  2. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    28,355
    The Borders
    +3,432
    HDBT has the potential to carry a 10/100 Network along with your HDMI signal.
    HDBT is not capable of carrying a Gigabit network - so may not be ideal in the long term.
    HDBT chip vendors also provide chip options which omit the 10/100 and many Matrix go with that option as unless you cannot run a second cable it is always better to run the network traffic on its own cable.
    Joe
  3. sellers75
    sellers75
    Sep 22, 2015
    5
    4
    England
    Thanks for your response Joe. So based on my understanding of your response my network diagram would work okay. The NAS as a media source to TV's through HDBT would be fine (even at 4K), but keep a separate cable for data transmission to wherever I need it. Eg pulling files, downloading etc?
  4. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    28,355
    The Borders
    +3,432
    I would keep the Network away from the HDBT Matrix and run it on a separate cable to every TV/Media player.
    The NAS will be storing data and your Media Players will pull the data across the network - you won't be rendering it as a video signal until it arrives at the Media Player (which could be inbuilt to the TV, a stand alone Player in each Zone or a centralised Media Player who's HDMI Output is then plugged into the HDMI Matrix).
    Ideally you will run 3 or 4 CAT6 out to each Zone - one of which will be used for HDBT to take Video Out to the Zone.
    Joe
  5. sellers75
    sellers75
    Sep 22, 2015
    5
    4
    England
    Great advice! Thanks...
