johnnyboy32
Hello, does anyone have any experience of these HDanywhere units because I cannot get any ARC functionality to work. I have a Denon AVR-X3500H with HDMI to the TX unit. I have also connected an optical cable from the unit into the "TV in" on the Denon. I have enabled ARC (HDMI control) on the receiver and the HDMI cable is connected to the ARC enabled HDMI socket. At the other end I have an HDMI cable from the RX unit (with the ARC button activated) running into HDMI 3 of a Sony AG8. I have activated BRAVIA Sync which enables HDMI control on the TV. I encounter no problems when using any of the sources from the AVR but when I use any of the apps on the TV or any of the sources switched through the TV I get no sound. Any ideas would be most welcome. Do I need an optical cable at the TV end? The HDanywhere manual isn't that clear.
