Question HDAnywhere mHub 4k
Discussion in 'Cables & Switches' started by KamSandhu44, Jun 16, 2015.
  1. KamSandhu44
    KamSandhu44
    Nov 25, 2009
    392
    28
    Slough
    +58
    Hi All,
    I am looking in to the posibility of get the mHub 4K. I currently have 4 HDMI sources, which could increase in the near future. What would my options then be? Would it be a case of having two mHubs with a network switch?
    Or would I be looking at a different product?
    Thank you,
    Kam.
  2. cmclean
    cmclean
    May 29, 2003
    1,014
    +119
    Hi Kam
    A couple of options as 2 x mHubs wouldn't work well
    Do you think you might also increase your outputs too?
    If so you'd be better going for a 6x6 HD Matrix. Although HDanywhere don't make them other manufacturers do
    Or you could buy the modular chassis version and then just populate exactly what inputs/outputs you want giving you up to 8 inputs and 8 outputs should you need them in the future it gives your lots of expandability
    Let me know if you want any more help
  3. Member 581642
    Member 581642
    Jan 3, 2012
    11,106
    +2,501
    HDMi Over Cat5/6 Matrixes dont work with network switches or over a IP network, they use dedicated Cat5/6 cable runs from the matrix (hub) to thereceivers.
    If you had more than 4 sources then you would need a matrix with enough inputs for the sources you need, you also need to consider how many TVs you want to connect to.
  4. KamSandhu44
    KamSandhu44
    Nov 25, 2009
    392
    28
    Slough
    +58
    Thank you for the replies.
    So currently I have 4 sources and 3 TVs.
    Within the next year that will increase to 6 sources and 4 TVs.
    Further in the future I will be adding more TVs.
    The HDAnywhere 8x8 modular matrix looks rather appealing.
  5. Member 581642
    Member 581642
    Jan 3, 2012
    11,106
    +2,501
  6. Member 319784
    Member 319784
    Nov 3, 2008
    1,502
    Malvern
    +240
    Hey Kam,
    I think that you follow us on twitter and facebook- cheers for your support. We will be releasing an mHub 4K 8x8 model over the coming months. I guess the main question is what source devices are you using and what resolution of TVs are your planning on having? There's an mHub 2K 8x8 that supports Full HD 1080p from eight HDMI sources to a maximum of eight displays over Cat 5 / Cat 6 cable runs up to 50m.
    let me know,
    Dee
