HDAnywhere 4x4 convert to POE
Discussion in 'Cables & Switches' started by ybotc, Jul 29, 2018.
  1. ybotc
    ybotc
    Apr 25, 2009
    61
    hello all
    Before I blow something up thought I would check here
    I have an old HDAnywhere 4x4 matrix (non POE) , if I buy a POE injector and splitter would it work (I know POE use the unused wires in Ethernet connection , but not sure which wires are used in th HDAnywhere connection)
    Toby
  2. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    28,917
    The Borders
    +3,569
    Contact HDAnywhere - they will let you know if what you are planning is possible (or not)!
    Joe
