HD950 vs 2910
Discussion in 'Blu-ray & DVD Players & Recorders' started by olimalaysia, Jun 8, 2005.
  1. olimalaysia
    olimalaysia
    Dec 16, 2004
    16
    is it worth paying the extra dosh for the denon?
    will be using for dvd playing only on an infocus 4805 on 80 inch screen
    thanks for you help
  2. gingerone
    gingerone
    Dec 10, 2002
    2,549
    +373
    Yes, yes and yes.
    I don't think you can really compare these machines. the denon is superb.
    If I'd been able to afford the denon I would have bought that without hesitation.
  3. Unlight
    Unlight
    Jan 6, 2003
    1,438
    38
    Belfast
    +9
    In all honesty - no.
    I have had a Denon 2910, and while it is a fantastic player, I simply dont think its worth £500.
    The picture quality and sound quality are NOT over three times better than what the price would suggest. Yes, the build quality is great and its a fantastic DVD Player, but I would stick with a Samsung 950.
  4. KoThreads
    KoThreads
    Jan 18, 2005
    3,012
    +179
    The 950 isn't available yet and looking at the 850 thread you might be better off avoiding it until the reviews start coming in.
  5. gingerone
    gingerone
    Dec 10, 2002
    2,549
    +373
    it looks like the 950 is going to be exactly the same as the 850 but with dvd-audio and sacd.
  6. zoro
    zoro
    Jan 23, 2003
    324
    +7
    950 has DCDI chip and has both DVI/HDMI, while 2910, only HDMI.
    I'll expect 2910, sounding way better!
    Both if share same DCDI chip might suffer from MB.
    UK 950 also do DIVX, 2910, does not.
    Both do Pal to Ntsc and are region hackable!
    950 is way cheaper and does come with free cables!! 2910..nada!
    I own a 850 right now and am very impressed with PQ, esp Pal to Ntsc upscaled is best that I have seen.
    Denon should have a more smoother, refined looking image!
  7. ozdvduser
    ozdvduser
    Apr 21, 2003
    170
    At The Track or Melbourne Victoria Australia
    +3
    Why convert, the 2910 can output PAL & NTSC natively
    2910 has both DVI & HDMI
    Free Cables !!!- your better off buying decent cable rather than use the crappy ones supplied
  8. zoro
    zoro
    Jan 23, 2003
    324
    +7
    no objection, if you wana pay for all that, it is your money, by all means, be my guest!
