hd950, dv575 but which is better???
Discussion in 'Blu-ray & DVD Players & Recorders' started by jimjim, Oct 22, 2005.
  1. jimjim
    jimjim
    Oct 22, 2005
    this is my first post here.
    I'm getting a new dvd player and I wanted one that played sacd and dvd-audio. In my price range it seems to be between the pioneer dv575 and the samsung hd950. Which of the two is concidered the better machine and why. I will be buying a region 2 PAL player but dose any one know if either can play ntcs native i.e. not as PAL 60 converted. Is there any other player around the same price that I should look at?
    thanks for in advance for taking the time to help out a noob
  2. paulst10
    paulst10
    Dec 16, 2004
    12,878
    Essex
    +2,313
    what screen do you own? do you have HDMI , DVI , component inputs ??
    i had had a 575 and i couldnt find a better picture for the price, i my experience, because a dvd player up-scales to HD it doesnt mean the picture will be better, as it image is scaled twice (once in the player then again on screen).
    the pioneer doesnt up-scale but has component video, and the image is spot on, and personally i think the pioneers are are just better all-round players.
    you could try getting a demo of both of them
  3. PJTX100
    PJTX100
    Dec 21, 2004
    8,144
    +564
    It only scales twice if you upscale the image to a res which isn't the native res of the screen. Upscaling to 720p for example in the DVD player and feeding to a 720 native res display means that the display will not scale the pic.
    Either way I'd still go for the 575...PJ
  4. jimjim
    jimjim
    Oct 22, 2005
    im just going to be connecting it to a regular crt tele, nothing flash.
  5. paulst10
    paulst10
    Dec 16, 2004
    12,878
    Essex
    +2,313
    then it has to be the pioneer 575 , either scart or component, you wont be dissapointed
