HD70 - blurry 360 Dashboard ?
N
Not A Clue
I have a 360 which I use with my HD70 (via. component) and I get slight blurring on the 360 dashboard where theres almost a shadow effect on any text (like a ghost image)...has anyone had this problem and no of a solution?
Could it be because its via. component and not VGA ?
Thanks for your help.
:lease:
Member 55145
is your 360 set to 720p? maybe youve accidently hit the switch back into normal composite mode (SD)
cant think of any reason other than using a resolution that isnt 1280x720
i take it its fine on everything else?
N
Not A Clue
Thanks for the response - worked out the issue. I had three component connectors to extend the wire and they were touching. Moved them away from each other and the picture is now fine :thumbsup:
