Hd600 And Xcans Distortion
Discussion in 'Headphones, Earphones & Portable Music' started by alanelmop, Aug 13, 2005.
  1. alanelmop
    alanelmop
    help me please.I have just brought a brand new pair of HD600 headphones.I plug them in to the Xcans and the left hand channel distorts.I plug my old HD477 headphones into the xcans and they are fine.I plug the HD600 into my amps and they sound fine.I have replaced the valves in the xcans and its made no difference.New headphones distort old ones dont.Does anybody have any ideas as to what the problem may be.
  2. extremelydodgy
    extremelydodgy
    Oct 27, 2004
    2,258
    +64
    Hmmm... Sounds like a problem with the amp itself, doesn't it? I would suggest you post on Head-Fi.org. The chances of you getting a solution there would be much higher.
