HD5H Sonicstage crash - 'hidden' files left on device?
B
b0rk
Hi all,
I was transferring over some MP3s > HD5H using conversion to ATRAC3Plus 64 then Sonicstage crashed at 52%! I was transferring maybe 4Gb over @ 192 so I guess thats about 1.5Gb - 2Gb in ATRAC3Plus meaning about 1Gb was transferred before the crash.
The thing is I can't remember exactly which albums I was copying across in that particular session (as re-inited device yesterday) but I'm not 100% convinced that the data that DID transfer is showing up in my HD5H Album/Artist list but I AM convinced the data is on the device. (as the free capacity has decreased by 1Gb). This is something I suspected happened once before using SS3.2 but again I didn't remember exactly what I transferred so I couldn't verify this :/.
Does anyone know for sure what happens to the data when SS crashes half way through a conversion transfer (possibly from experience)? As I said, I may well be wrong and the data that did transfer is showing up fine!
batesym
Found this thread from a while ago. It may answer your question.
http://www.avforums.com/forums/showthread.php?t=240220
I had a similar problem a while ago, although I dont think it's exactly the same as what you're describing. MAke sure you give sonicstage enough time to upload. Sometimes I found it appeared to freeze at 99% only to resume after a minute or 5.
P.S SonicStage 3.3 out now. You may want to upgrade now, if you havent already ripped all of your music!!
B
b0rk
hiya,
This is using SS 3.3 so latest version! and I mean a true crash whereby it throws up 'Omnijukebox.exe... memory error... blah' then closes!
I'll check out the thread thx!
B
b0rk
Hiya,
mmm its similar but not quite the same problem - this is when there is a posibility of files being left on the device but not actually showing up on the device or via SS!
mmmm!
