HD50 -v- HD45 & Best Scart Leads?
Discussion in 'General TV Discussions Forum' started by mpress, Mar 8, 2005.
  1. mpress
    mpress
    I think I have made the decision to give back the HD50 sold to me as an HD ready TV and accept the HD45 as the replacement option.... is this a good move or do you good people have any suggestions before I commit??? :rolleyes:
    I am being told that it is crucial I get great scart leads to eliminate fizzing on the sky menu etc and encode the signals accurately...
    Any thoughts on this and also which ones should I get as they seem to range from £5 upto £000's! :eek: I have been told Monster or Profigold but I am a novice to this and would appreciation some opinions :lease:
  2. St_ve
    St_ve
    Jan 6, 2005
    1,059
    39
    Birmingham
    Make sure you demo the HD45 first
  3. mpress
    mpress
    Hi St_ve... thanks for the advise... do you expect me to find things that are below the standard of the HD50?
    What is your opinion of the HD45 then? Did you have any comment re the scart lead issue also? :confused:
  4. St_ve
    St_ve
    Jan 6, 2005
    1,059
    39
    Birmingham
    Havent seen the HD45 but there have been posts about a speckled screen effect as if the image was oversharpened the screen might be too bright and look better in eco mode.It might be a fantastic set but to Demo any set first will allways be good advice.
  5. zAndy1
    zAndy1
    Nov 26, 2002
    22,930
    2
    5
    163
    +9,379
    QED do nice scart leads, you don't need to spend a fortune, depends what length you need but £40 will get you a good one that will ensure you're getting as much out of the source as possible without spending daft money!
    Cheers,
    Andy.
