hd5 too quiet?
L
liverdes
i just bought this player, and although it is very nice looking, i think that it is way too quiet! even whn i have cracked the eu limit, it is still too quiet! does anyone else have this problem? also, there are 14 tracks in my collecion that, for some reason, i cannot transfer to the player! can anyone help me?
sirlukas
Established Member
Are You sure, that You cracked the EU Noise restriction?
Did You Confirm by pressing play button, or went back without doing it in the Service Menu?
D
dskywalker
You probably need to check c if you've done the uncap right. Or you could be using high impedance head/earphones. I use e4c canalphone and i think volume about half way is adequate. Otherwise, check your ears? :D j/k
S
szsiddiq1214
lol, i must have hyper sensitive ears, when do u people turn up the volume so high? and if u need to, u might wanna resist doing so, cuz ur gonna kill ur ears!
sirlukas
Established Member
Maybe the best way, would be to put earphones properly into ears ;)
F
flushme
i do understand your discontent. It's quiet. You just have to live with it. tiny flash-players (any brand) are even louder. I suggest you go for AKG K26P (the light in my life right now :smashin: )
Chox1988
If you have cracked the EU limit which I don't think you have by the sounds of it, and it's still quiet get a cheap small external amp. Just search headphone amp on ebay and set HD5 to line out and play through the headphones.
drmoze
Also, what type of headphones/earphones are you using? You want to use phones with at least 102-104 db/mw sensitivity for good volume.
BenW
Established Member
Have to say i find my unlimited HD1 with shure e2c comparetivly quiet when its on 'full' volume :s.
LG G3 MLA OLED Evo Best Picture Settings - works for ALL 2023 LG OLEDs
Back
