HD5 "Sound off/on" problem...
Discussion in 'Headphones, Earphones & Portable Music' started by mohip, Jun 15, 2005.
  1. mohip
    mohip
    i just bought my HD5 today, and love it, but theres one major problem, i wonder if any current owners can help or advise...
    when in options, and selecting "sound", it says "off". to change this i need to click on it to make it "on", and then hear any changes i make in the equlaiser...
    but it wont select "on" at all, its not the buttons, as i can change every other variable, but it just wont let me hear the changes to sound.
    i dont know if i need to do something, or is it a complete fault?
    thanks in advance, if any of you can help :)
  2. davisneil
    davisneil
    May 15, 2005
    396
    +19
    are you playing mp3 files?
    the sound equalizer will only work with atrac files. Use the 'digital sound preset' function with mp3 to change bass/treble
  3. mohip
    mohip
    ok im new to this so ill tell you what happens:
    first off, i transferred some mp3s and it would select "sound on", so i figured it might be as you said, but then i transferred some tracks off CD, which i presume are atrac, yes? well it wont change these either.
    am i doing something wrong?
    edit : ive just looked at the properties for an album i just put on, and it tells me the format is atrac3plus, and i still cant change sound while its on :confused:
