HD5 software
Discussion in 'Headphones, Earphones & Portable Music' started by ElmoP, Jun 1, 2005.
  1. ElmoP
    ElmoP
    Jun 1, 2005
    108
    First time posting - can't believe I've only just found this site!
    Anyway, I've got a problem with my new HD5. Can't get sonicstage to load for love nor money and it's INFURIATING! :mad:
    I always get the same error on opening the program - "Cannot find the database file, or the database is corrupted". I've found a load of different fixes on the web, and none of them work for me.
    I'm running Win2000 Prof with AMD-K6 processor.
    Can anyone help? Either with alternative software or a fix?
    I'm considering taking the damn thing back and getting an ipod - I'm that desperate...
    Thanks in advance.
    ElmoP
    PS - the volume fix worked first time. Nice one.
  2. ElmoP
    ElmoP
    Jun 1, 2005
    108
    Lots of people have read my post but no replies... :confused:
    Does anyone else use Win200 professional with sonicstage? If that's the problem, it may be time to update my operating system to ME...
    Any thoughts? I'm really, really stuck! :lease: :lease:
  3. mcfarfs
    mcfarfs
    Mar 11, 2005
    1,368
    41
    Tunbridge Wells
    +12
    SonicStage doesn't work well with anything but XP. I suggest you upgrade to that, because it is a much better OS anyway!
  4. ElmoP
    ElmoP
    Jun 1, 2005
    108
    Thanks! I'll look into doing that. :thumbsup:
    Will I have problems with the XP SP2, or have all those probs been sorted out now?
  5. mcfarfs
    mcfarfs
    Mar 11, 2005
    1,368
    41
    Tunbridge Wells
    +12
    I don't know, but I have never had any problems.
  6. wilto
    wilto
    Apr 23, 2005
    309
    Cardiff
    XP is fine now.
    Will 2000 work with sonicstage 2.1?
  7. JB5
    JB5
    Apr 18, 2005
    231
    +16
    I'm using SS3.1 with win2K, without problem.
    Loaded SS2.3 from disk supplied with NW-HD3, and then upgraded online to SS3.1.
    Are all your win2k patches up to date?
  8. sunflowerhx
    sunflowerhx
  9. ElmoP
    ElmoP
    Jun 1, 2005
    108
    Yup, all patched. Just didn't want to work. XP is going on at the weekend so I should be in the position to finally rip some cds and get my HD5 going!!! Can't wait :clap: :clap: :clap:
