HD5 Playlists
Discussion in 'Headphones, Earphones & Portable Music' started by danwalton, Jul 27, 2005.
  1. danwalton
    danwalton
    Feb 15, 2005
    2,382
    +129
    Hi, I can't find a clear description of HD5's playlists anywhere, so could someone just explain how they work? I have an HD1 so I understand all about bookmarks. Is it possible with the HD5 to put the same song in multiple playlists? For example could I have 'Don't look back in anger' in bookmark 1 and 3 etc on the HD5? Thanks for any help! Dan
  2. shadowritten
    shadowritten
    You can both bookmarks AND playlists on HD5. Bookmarks are playlists you make on the go (but only while tracks are playing); Playlists have to be made in SonicStage and transferred to HD5.
    And yes, you can have same tracks in different playlists/bookmarks.
  3. sk79
    sk79
    Jun 29, 2005
    36
    quick question: I've transferred all my music to my HD5 and deleted the atrac files from my pc, so my libary in SonicStage is empty.
    To create these playlists, can I work straight from the HD5 or do I need to copy them back to the pc?
  4. shadowritten
    shadowritten
    sk79 - you need to copy them back first, sorry!
  5. Hrochnick
    Hrochnick
    Apr 28, 2005
    369
    Brno
    +9
    Don't copy them back from the HD5, that'll just result in them being deleted from the HD5 and you left with no music. You'll need to reburn your tracks in order to keep them on the player and make playlists. You might even need to delete them from the HD5 and re-transfer but I'm not sure about that one.
    In my opinion - not a good idea to delete stuff in SS that's still on your HD5, keep everything or it'll only lead to trouble.
  6. danwalton
    danwalton
    Feb 15, 2005
    2,382
    +129
    another question: so if I create a playlist in SS and transfer it to the HD5 can I then edit that playlist on the go? For example can I add and remove songs to/from the playlist on the player itself? Cheers!
  7. shadowritten
    shadowritten
    Afraid not.
    Playlists made on SonicStage can only be edited with SonicStage. Bookmarks made on the player can only be changed on the player.
  8. sazza42
    sazza42
    Looks like I won't be able to use playlists then... I have the problem of having a 20gb HD5 & an antique (but lovely) computer with a 5gb hard drive. I obviously have had to transfer tracks over to my HD5 & then delete them from my computer. No way round it I suppose...
