HD5 - Line Out
Discussion in 'Headphones, Earphones & Portable Music' started by shadowritten, Aug 5, 2005.
  1. shadowritten
    shadowritten
    Just a little tip for anyone as stupid as me: Don't be tempted to do as I did last night and risk perforated eardrums/knackered phones by switching from 'Headphones' to 'Line Out' in Audio Output settings while listening to tracks THROUGH YOUR HEADPHONES!!!
    By God, it's deafening :suicide:
    On the plus side, also tried switching to Line Out and using a bog-standard FM transmitter through my hifi - works an absolute treat. Very loud, very clear, and better than I'd expected given my crappy home equipment.
  2. Sasso
    Sasso
    ahaha Ive done that too!...By accident....keep forgetting to switch it over when i put my headphones in and man it gives me a big shock, thing is it isnt just loud, its distorted and crackling, obviously not enough power to deliver at such volume to headphones, or could be the phones.....either way its aweful........but it is excellent when you set it to line out and actually use it for line out....sounds like CD quality. :)
  3. shezzy2k
    shezzy2k
    Aug 17, 2004
    492
    28
    +26
    LOL....I thought it was just me!!
    I received my HD5H yesterday and managed to do the same. Thankfully I was wearing the crappy headphones that come as standard.
  4. sazza42
    sazza42
    One way of getting round making this mistake is to get some headphones with a remote - you know, the ones that an extra bit where you plug them into your HD5. It seems to know that the difference between this & an ordinary connector cable & switches the output over automatically. You still need to change the output over to line out when you plug into your home system though. Saves your eardrums anyway!
  5. HD3
    HD3
    After having my HD3 plugged into my amp i do it amost everyday when i walk out the front door. You would have thought i'd learn by now. Or maybe its just deafing me slowly so i don't notice anymore.
  6. Dokken
    Dokken
    Oct 10, 2004
    81
    +5
    Hi Shadowritten,
    What fm transmitter do you use? Is it any good, how much did it cost and where did you get it, if you don't mind me asking.
  7. shadowritten
    shadowritten
    It's the wife's: a Ross one she got off eBay for £10. Takes two AAA batts, and does a pretty good job through my entry-level Technics system.
  8. WAYNE509
    WAYNE509
    Jan 6, 2004
    551
    Fife Scotland
    +14
    Kind of following up on this thread err
    For use in the car would you use the cassette adaptor(yes i know but you just dont have good sounds in the wifes car :D ) or the FM transmitter.
    Cassette gotta be better right?
  9. Sasso
    Sasso
    I use an old cassette adaptor that came with my old sony car diskman. Of couse it was useless since it had the very first Electronic Skip protection and would skip every 2 seconds unless you held it sideways. So i never used the tape until i got the HD5 and its excellent quality in the car.....makes a little noise when its playing, but i can't notice it anymore.
    You would never have been able to tell it was a cassette, from a portable player. And my speakers are not bad.
  10. shadowritten
    shadowritten
    Just got me a line out cable. Boy, I'm impressed! Even through my entry-level set-up, the sound is fantastic. Particularly when you consider the following:
    1) Downloaded a 160kbps MP3 from the Net
    2) Converted it to WAV
    3) Turned into back into a 320kbps MP3
    4) Converted it to 64kbps ATRAC3Plus
    Why? Just to test how all this mucking about would harm the SQ. And you know what? Can't discern any noticeable difference. Still sounds superb!
    Man, my ears must be screwed ...
  11. mrflabby
    mrflabby
    Jul 8, 2005
    53
    11
    Is there a way to get a line-in for the car stereo/does it depend on which stereo you are talking about? I'd love to be able to connect my hd5 to my car stereo and fm transmitters have such bad reviews!
    Thanks!
  12. Sasso
    Sasso
    Use a cassette adaptor for your car. Its excellent.
  13. mrflabby
    mrflabby
    Jul 8, 2005
    53
    11
    It's a cd stereo so unfortunatelly no cassette adaptors for me. :mad:
    That was the reason for my post.
  14. Sasso
    Sasso
    Ah, how annoying, you'll probably have to use a radio transmitter, unless you have a line input socket on the front of the stereo.
  15. AlexGarfield
    AlexGarfield
    lol i was playing with the menu too. it scared me real bad
  16. shadowritten
    shadowritten
    As an aside, also tried my old Zen Touch using my new line out cable (JVC, in case it matters!), and while the Touch doesn't have line out capabilities, it does perform surprising well on volume/headphone output alone.
  17. IanPM
    IanPM
    Jan 12, 2004
    389
    +6
    A lot of modern car stereos have a line in at the rear. Sony's I beleive do, for example. There may even be kits to hack the input for a CD multichanger... That would open up potential on a lot of cars (VW's use Sony for a while as their autochanger)
  18. shadowritten
    shadowritten
    Line in at the rear? Other than Sony, do you know which brands?
  19. turbo1
    turbo1
    Aug 14, 2005
    39
    2 phonoes to a amp in the boot wired to the speakers (brill) :clap:
  20. David Mackenzie
    David Mackenzie
    Aug 28, 2003
    10,213
    Glasgow, UK
    +1,310
    Yup, happened to me too with my earbuds, turned up to full volume! Scared the living crap out of me. Sony should put on a first-time warning.
  21. Sasso
    Sasso
    I'm paranoid every time I press play, I can never remember if its set to line out or not. There should be a symbol on the playback screen if it is...another bad move by sony.
  22. jaskaran
    jaskaran
    hi, anyone know if the hd5 will be compatible with these new bitrates on sonicstage 3.2, i tryed a 320kbps atrac3plus and it didnt work, but a 192kbps atrac3plus DOES work in some cases?? wondering if sony could make a firmware update.
