HD5 Elapsed time flickering
Discussion in 'Headphones, Earphones & Portable Music' started by elzofran, Jun 2, 2005.
  1. elzofran
    elzofran
    I was wondering if anyone else who has an HD5 has noticed that the elapsed time and the corresponding "bar" flicker, or change time irregularly soon after you turn the unit on. althoguh it does seem to settle down after a while.
    cheers
  2. David Mackenzie
    David Mackenzie
    Aug 28, 2003
    10,351
    Glasgow, UK
    +1,312
    I've never had that - odd.
  3. caaralagueva
    caaralagueva
    this doesn't happen with mine either. does it happen only on certain mp3s/atrac files? or with all songs?
  4. Hrochnick
    Hrochnick
    Apr 28, 2005
    369
    Brno
    +9
    That happened with mine on occaision, where the seconds would zoom up and then stop and the elapsed time bar would shoot forward and move back. Only happened once or twice but I put it down to the overall problems I was having with system crashes. That player has been returned. I couldn't say now what type of file it happened on unfortunately.
  5. mcfarfs
    mcfarfs
    Mar 11, 2005
    1,368
    41
    Tunbridge Wells
    +12
    I had that problem with my HD3, very occasionally.
  6. Simebaby
    Simebaby
    Sep 17, 2004
    769
    +21
    I've got a feeling this only happens with variable bit rate MP3's (waits for someone to prove him wrong!)
  7. wilto
    wilto
    Apr 23, 2005
    309
    Cardiff
    i get this sometimes too on my HD5.
