HD5 - Confused about content when viewed as hard drive
Discussion in 'Headphones, Earphones & Portable Music' started by twynne, Jul 8, 2005.
  1. twynne
    twynne
    Jun 3, 2005
    81
    +4
    Hi all,
    Happened to connect my HD5HS to my laptop this morning (usually connects to a desktop PC) and out of curiosity browsed the player using Explorer. It seems I have both an OMGAUDIO folder and a 'Music' folder which contains my entire library (or most of it) in WMA format. I'm not sure how this got onto the player as I've never manually placed anything on it other than via Sonicstage. Is it possible that WMP chose to sync my music onto this and I missed a prompt (or wasn't asked!) And if so am I safe in deleting the 'Music' folder?
    Was surprised by the device reporting it was full when I tried to transfer tracks, and suspect this is the reason!
    Thanks for any advice.
    Tom
  2. JB5
    JB5
    Apr 18, 2005
    231
    +16
    I would be cautious of deleting anything from your player using explorer.
    I would recommend either deleting any unwanted files from within sonicstage or formatting the device and re-transferring your library (if still available).
    If you were feeling brave however and you have backed up your PC library using sonicstage then give it a go!
  3. sxc
    sxc
    Jun 5, 2005
    56
    +4
    I would guess that WMP synced your music. When I plug in my HD5, I get a prompt which starts the sync wizard. If you accidentally press enter it will start transferring.
  4. twynne
    twynne
    Jun 3, 2005
    81
    +4
    Thanks - I cut/pasted onto my laptop just to be sure and the player still works fine. This was definitely not something that needed to be there. Looks like a caution to anyone else... that had used up 1/3rd of the available space on the player!
