HD5 battery - let it run flat?
Discussion in 'Headphones, Earphones & Portable Music' started by myepitome, Jul 16, 2005.
  1. myepitome
    myepitome
    I never know this...but should you let it flat then charge it? or charge as you want?
    Also bizzarely I had the convert to atrac setting on, but then only some decided to convert...and the rest are mp3s...
  2. kamp
    kamp
  3. pjskel
    pjskel
    Oct 12, 2004
    2,687
    83
    UK
    +122
    For best battery life with Li-Ions, recharge fully and as often as possible, rather than deep cycling them. I.e don't dicharge to the point where the unit turns itself off before recharging.
    Just like mobiles, plug them in every night.
