HD3 Playlists
Discussion in 'Headphones, Earphones & Portable Music' started by sacd, Apr 18, 2005.
  1. sacd
    sacd
    Feb 19, 2004
    295
    Cardiff
    I have sonic stage 3 installed and have just spent 5 hours this afternoon tidying up my library of music. I even spent time making up playlists. My HD3 is now blank and want to transfer everything I have done over to it.
    However, how do I transfer all my songs over to my HD3 along with the playlists without items being doubled?
    It seems to me that if i transfer a Ministry of sound album over to the hd3 and also a playlist with some of those albums traks on it I will end up with those tracks on twice!
    Is there anyway of stopping this?
  2. Scarylion
    Scarylion
  3. shelteringsky
    shelteringsky
    No. the hd3 doesn´t make proper playlists. maybe the hd5 (and hopefully hd3 with it´s firmware upgrade...) Yeah, I know: It´s a crap, but nobody is perfect....
    there is a "way" of making some kind of "playlists". they´re no proper playlists but do their job... You can change the genre properties on the songs you want and put them another name like "playlist 1: ministry of sound" instead of "house" or whatever...So, when you want to listen to it, you only have to go to genre and playlist 1: ministry...
    It´s interesting if you don´t use genre property usually. otherwise...
