HD3 Connector Fix
Discussion in 'Headphones, Earphones & Portable Music' started by Fencer02, May 13, 2005.
  1. Fencer02
    Fencer02
    MY MY It never happens does it Sony............
    Go to http://www.sony.co.uk/PageView.do?s...1&article=1115723714577&section=en_GB_Support
    Here you will find details of how to send your HD3 back to Sony if it has a serial number between the ranges specified. This corrects a fault mentioned on this forum on several occasions in reference to the internal connector which "May become detached".....
    I may become detached from Sony Products .......this HD3 is continuing to exibit traits which would identify it as having been rushed to market The HD5 is the real product ...... (Playlists Ect)
    Not good enough...............
  2. sacd
    sacd
    Feb 19, 2004
    295
    Cardiff
    Great!! Mine's included.
    What was the problem anyhow?
  3. FifeFlyer
    FifeFlyer
    Feb 12, 2005
    Fife, Scotland
    I'm not experiencing any problems.... should I send it for repair?
    How long does it normally take for Sony to repair and return a unit?
    I got the HD3 as a replacement from Argos as my Thomson Lyra PD2840 was "unrepairable" (the on/off button stopped working!!). I thought Sony would be reliable thus my reluctance to send my HD3 away for repair, as the saying goes "if it ain't broke; don't touch it!"
  4. sacd
    sacd
    Feb 19, 2004
    295
    Cardiff
    I think the problem we all have is this---if we don't send it in for repair and the problem manifests itself some time in the future after the guarantee has gone then we may be up a certain creek without a certain implement. But I may be wrong in thinking this.
  5. mrtbag
    mrtbag
    Dec 17, 2002
    3,509
    Anywhere I want
    +395
    It does say on the site, if your serial number is in the range, send it off. If it isn't don't. It's free, and my Minidic player was turned around in 8 days when I sent it off.
  6. robpok
    robpok
    Although my HD3 is not in that serial number range, mine stopped working (it didn't go past the "Walkman" screen when I turned it on - I think some posts here indicated that this was due to the problem that the Sony recall is talking about; the connector at the back coming loose). Anyhow I sent it back to Sony and in answer to FifeFlyer's question it took exactly 3 weeks to come back.
  7. DrDweeb
    DrDweeb
    Min was replaced on the spot at Dixons
