HD2 DLP with 2.6 throw ?
Discussion in 'Projectors, Screens & Video Processors' started by ijwoo1, Jan 19, 2003.
  1. ijwoo1
    ijwoo1
    Sep 29, 2002
    Billericay, Essex
    Does any one know of an HD2 based DLP projector that either comes as standard with a long throw lens or where its available as an option ?
    I'm looking to replace my Sim HT200 which currently projects onto a 7FT 16:9 screen from 18FT.
    I might be able to reduce the lens-screen distance to 17FT (2.5 throw) but a 2.6 throw would be ideal ?
  2. ijwoo1
    ijwoo1
    Sep 29, 2002
    Billericay, Essex
    I forgot to mention that another option is that the projector goes between the viewer and the screen and off to one side which would allow me a much smaller throw but how much horizontal keystone could I typically apply ?
    The HT300+ for example allows +/-21 degress of adjustment (I think). At 12FT from the screen does this mean I could have the projector offset to left/right of the screen centre upto 54" ? That sounds a lot so I don't think I'm calculating it correctly.
    If it is possible to offset left/right do you end up with one side of the image brighter than the other or any other side effects ?
