HD15 to 3 RcA
Discussion in 'Cables & Switches' started by oliver24, Sep 23, 2004.
  1. oliver24
    oliver24
    I have just got an Iscan ultra and i need a
    vga cable (HD12) to a 3 rca cable (Sync on Green)
    Any Ideas?
  2. pjclark1
    pjclark1
    Jul 19, 2004
    4,411
    Thailand
    +271
    buy a vga to 5x bnc lead on ebay (I just had one for £5.20 delivered)
    cut the RGB bncs off (or get 3 female BNC to male phono adapters)
    and solder 3 RCA plugs in their place, it's what I have done.
  3. oliver24
    oliver24
    Right so I RGBHV cable is ok then, I just use 3 of the 5?
    Is there no diffrence in picture quality with a bigger cable, the ones
    on ebay look very thin!
  4. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    24,270
    The Borders
    +2,572
    Oliver24
    01. Are you not outputting YUV from your Ultra - not many displays in Consumer land will work with RGsB.
    02. HD15 to 3 or 5 RCA cables - yes the cable can and does make a visible difference; especially so over long cable runs.
    We have plenty of these in stock http://www.bettercables.com/silservga.html
    - and also supply the same configurations using lower cost VanDamme Red Series cable.
    Others on the Forums manufacturer and supply alternative brands of cable.
    Best regards
    Joe
  5. oliver24
    oliver24
    I will be outputting YUV and going in the Component 3x Phono's on
    my LG DLP TV
    I see thats a US site, any uk sellers?
  6. Thunder
    Thunder
    Feb 26, 2004
    1,763
    41
    +14
    Keene will make you one up for a good price and good quality, www.keene.co.uk :thumbsup:
  7. pjclark1
    pjclark1
    Jul 19, 2004
    4,411
    Thailand
    +271
    going for £3.50 on ebay in the next 15 mins
    I had one of these, cut off the RGB BNCs & soldered on RCAs
    G = luminance
    R = y-r (Pr)
    b = y-b (Pb)
    works a treat!
    http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&category=3697&item=5124621303&rd=1&ssPageName=WDVW
    or here at £7 delivered
    or here at £6.55 delivered
    http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&category=67859&item=6705900544&rd=1&ssPageName=WD1V
  8. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    24,270
    The Borders
    +2,572
    Oliver24
    Anything you see on the BetterCables website we can provide in the UK - VGA breakout to 3 or 5 BNC/RCA are normally held in stock in the UK.
    Best regards
    Joe
