HD15 pinouts
Discussion in 'Home Cinema Building DIY' started by alpha10, May 19, 2004.
  1. alpha10
    alpha10
    Jan 22, 2002
    3,197
    Essex
    +191
    Hi all,
    This weekend I am going to be messing around making up some custom cables from the DVD (component prog scan) to projector.
    So I’m going from 3x RCA to HD15 could someone just confirm for me that the only pins I need to connect up are as follows:
    VGA, HD15 PLUG END:
    pin1= red
    pin2= green
    pin3= blue
    pin6=red ground
    pin7=green ground
    pin8=blue ground
    I don’t think I have to do anything else, but having read so much stuff (after searching the forums :D ), I’m a little confused if I need to ground pin10 to the shell, and or link 13/14?
  2. MarkHudds
    MarkHudds
    Jun 12, 2002
    548
    +4
    Hi, unless your projector has the unusual capability of accepting component (YUV) on the RGB pins of the HD15 VGA connector then I don't think this will work ...
    The HD15 is for RGBHV signals (like from a PC) and not YUV component.
    Does your projector not have 3 RCA's for component input?
  3. alpha10
    alpha10
    Jan 22, 2002
    3,197
    Essex
    +191
    Hi Mark,
    Thanks for the reply..
    [snip]
    [snip]
    That is exactly what the Themescene H30 can do :D and why I called the connector a HD15 and tried to avoid the VGA confusion....
    I have actually tried this and it works fine, I was just unsure if it was better to still ground the pin10 to the chassis or not (I haven't yet)?
  4. rubadub
    rubadub
    Does anybody know if those are all the pins required. My plasma is arriving today and I have no cables! I plan on making a makeshift cable, just sticking 75 ohm coax into the pins from my pc to the plasma (panasonic 6W) but want to know the amount of wires I need
