HD15 pin ? Is it VGA ?
Discussion in 'Plasma TVs' started by happyhiker, Jan 21, 2005.
  1. happyhiker
    happyhiker
    Jan 3, 2005
    420
    +25
    Any one know if this is what I need to wire a JS RGB>VGA converter to my PW6 behind the walls ?
    http://www.keene.co.uk/pages/cat/16diy/16F.html
    Its a 15 PIN HD, is that the same as 15 pin D-Plug ?
    Its a female on both ends connection so I don't need to solder anything
    and looks just right But I'm not sure about the 'H'D bit.
  2. Nick_UK
    Nick_UK
    Nov 13, 2004
    9,748
    103
    +270
    Your link does not work. The Keene website is a pain in the butt. You will have to find the listing page that links to the product, right-click on the link, then choose "Copy shortcut", then paste it.
  3. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    23,762
    The Borders
    +2,464
    happyhiker
    Like Nick_UK I'm not attempting to navigate the Keene web site - its nuts!
    The JS Converter has an HD15 (VGA) Socket as has your Plasma Display - therefore you need a Male to Male HD15 Pin (VGA) cable - most JS Technology dealers will sort you out with what you want; as can the JS Tech web site if you want to go direct.
    Best regards
    Joe
