HD1 vs HD3 - what's the difference?
Discussion in 'Headphones, Earphones & Portable Music' started by toratosaru, Mar 14, 2005.
  1. toratosaru
    toratosaru
    I've looked at the Sony site and all I can figure is that the HD1 comes with a cradle. Are there are any more differences? is the HD3 an updated HD1? Thanks in advance for any help.
  2. mcfarfs
    mcfarfs
    Mar 11, 2005
    1,368
    41
    Tunbridge Wells
    +12
    The hd3 is shipped as playing mp3s, as oppose the the hd1 which converts them to atrac3 format before transferring.
    It is possible to send the hd1 to Sony for an upgrade so this to will play mp3s. I believe this costs £15.
    The other differences that I have noted are the hd3 has more options on the sound equaliser menu.
    The hd3 also has a blue/white/pink backlight (depends what colour you choose) instead of the green of the hd1. If you look at a photo of the two, they are slightly different in appearance. The final difference to my knowledge is that the hd3 is marginly chunkier than the hd1, and has a plastic top and bottom instead of metal.
  3. Stahlhart!
    Stahlhart!
    and the options you are talkin about are? Cause i didn't notice that...
  4. mcfarfs
    mcfarfs
    Mar 11, 2005
    1,368
    41
    Tunbridge Wells
    +12
    The hd1 was the "V-SUR" option, and "Sound EQ". The HD3 has these and another, "Digital Sound Preset".
  5. spikey1
    spikey1
    Jan 9, 2004
    459
    +18
    If you get the upgrade on the HD1 all the options from the HD3 are there making them basically the same unit with different body shells. IMHO the HD1 is better as its smaller, lighter and has a magnesium alloy body.
  6. al1980
    al1980
    Feb 2, 2005
    15
    I'd agree - comparing both players side by side, the hd-1 has a much nicer look to it. it feels more solid and slimline. The hd-3 feels a bit plasticky in comparison. Also, i've found the cradle you get with the hd-1 quite useful as it gives you somewhere to store & charge the player safely...
  7. watchinthewheel
    watchinthewheel
    i really wish i had known about the firmware update for the hd1 before i bought a hd3! still both are great machines.
  8. mcfarfs
    mcfarfs
    Mar 11, 2005
    1,368
    41
    Tunbridge Wells
    +12
    I have owned both, and am more pleased with the hd3. Admittedly, it is slightly larger. However, this is hardly noticeable and the better style of the hd3 (in my opinion) coupled with the blue/white/pink backlight as opposed to dull green on the hd1 makes it, i think, a better machine.
  9. pharris007
    pharris007
    Jan 30, 2004
    198
    Lancashire
    +11
    And dont forget you can turn the display to gegative so you can have green on black - cool.
    Just got HD1 from Sony centre for £145, can get firmware from Sony to play MP3 (if you want it, I find ATRAC fine) and you get an update of sonicstage too. all for £15.
    Bargin :thumbsup:
