Hd
Discussion in 'Satellite TV, Sky TV & FreeSat' started by Welshorp, Apr 25, 2007.
  1. Welshorp
    Welshorp
    Apr 2, 2007
    40
    Woop i get my box tomorrow, instead of me waiting and seeing for myself, does ne1 know fi normal sky channels will be upscaled?
    I don't really care coz i watched last yrs wimbledon on BBC HD in someones house i was working at and was amazed with the quality
  2. Starburst
    Starburst
    Jul 13, 2000
    17,846
    Ilkeston
    +975
    Yes every channel you can access via the STB can be upscaled and sent via HDMI or component or left as normal via the other analogue outputs.
    If you so choose you can specify that SD channels remain SD using the AUTO setting in the picture resolution option and HD will be HD thus letting your display scale the SD channels.
  3. Scapegoat
    Scapegoat
    Nov 19, 2004
    2,638
    Leeds
    +137
    If you have it set to auto then some TVs 'blip' when you move from a HD to a SB broadcast.
    i.e. Screen goes black whilst the resolution change is processed I think.
    I found very annoying and leave it set to 1080i - others prefer to watch SD as SD.
    Persaonally it doesn't make a big difference when watching non HD material, though non HD stuff on the HD channels e.g. Soccer AM, Nip/Tuck do look better IMO - not much, but enough to warrant watching over the other channel.
  4. mremulator
    mremulator
    Sep 19, 2005
    1,090
    Surrey
    +67
    Don't expect miracles though, even some of the HD stuff looks very mediocre IMHO.
  5. Welshorp
    Welshorp
    Apr 2, 2007
    40
    nope it looks immense!!!!
  6. Welshorp
    Welshorp
    Apr 2, 2007
    40
    so how do u choose whether the normal sky channels are upscaled or not?
  7. Starburst
    Starburst
    Jul 13, 2000
    17,846
    Ilkeston
    +975
    It depends what screen resolution you choose in the menu.
    1080i upscales SD to 1080i and leave HD as 1080i
    720p upscales SD to 720p and downscales HD to 720p
    Auto sends SD at 576p and HD at 1080i
    All HD channels on SKY are broadcast at 1080i resolution.
