hd-xa2 picture and sound settings query
Discussion in 'Blu-ray & DVD Players & Recorders' started by rowanhall, Jan 18, 2008.
  1. rowanhall
    rowanhall
    Aug 10, 2007
    13
    hey all!
    i have been fiddling around with my hd-ax2 and was wondering what the optimal settings would be.
    for my 427xd display i was wondering what settings i should have for:
    enhanced black level; rgb output range and picture mode.
    currently i have it set as follows
    black level OFF, RGB range STANDARD and picture mode AUTO.
    what difference is there between standard and enhanced for rgb range and what does the picture mode do?
    i have a pio ax4 amp set for 5.1, the player is attached to this via hdmi.
    should i just accept the default audio settings?
    sorry for all these questions, i'm a hd-dvd newbie!
    thanks,
    Rowan
  2. kingfats
    kingfats
    Dec 29, 2006
    36,741
    Windsor
    +8,967
    Hi mate :)
    Black level OFF
    RGB,standard..........( Enhanced is for DVI connection only).
    Picture mode AUTO.........auto selects,HD DVD,DVD,DVD RW,etc.
    Audio settings.
    Digital Out SPDIF---> Bitstream
    Digital out HDMA---->Auto
    Digital Direct Audio Mode----->On
    Dynamic Range Control------>Off
    Dialog Enhancement------>Off
    Speaker Setting------>5.1ch
    :thumbsup:
  3. rowanhall
    rowanhall
    Aug 10, 2007
    13
    thanks again kingfats! very much appreciated! :)
    not quite sure what 'Digital Direct Audio Mode' is though! but i have enabled it! :)
    cheers!
    Rowan
  4. kingfats
    kingfats
    Dec 29, 2006
    36,741
    Windsor
    +8,967
    Hi mate :)
    'Digital Direct Audio Mode' when enabled will send HD audio direct to a compatible amp so the decoding can be done there,instead of in the player. :smashin:
