HD Writer Ver2.1 Error msg whilst copying to media.
Discussion in 'Camcorders, Action Cams & Video Making Forum' started by Alleluia, Nov 28, 2010.
  1. Alleluia
    Alleluia
    Dec 20, 2008
    3
    London
    I am using a Panny HDC-TM700 cam and software HD Writer vers 2.1.
    I am trying to copy a video saved on my PC to a DVD.
    However, when I am copying to the disc and error comes up " An error occurred while the disc image was being copied".
    I keep getting this message . What an I doing wrong.
    Do I need to format/initialise disc before copying to media.
    Initialise function is not highlighted.
    Best wishes and thanks for any help you can give.
  2. Pilot
    Pilot
    Nov 30, 2010
    2
    I had a similar problem when trying to burn an 'edited' file to a dvd with I believe the same error message.
    My problem was caused by opening Adobe Picasa, a free photo editing program, at the same time as HD Writer was running. You are advised not to use Windows Explorer or indeed, any other program at the same time, so my problem was self generated!
    With the original edited file deleted (through HD Writer) and a new edited movie file made, all worked OK.
    Hope this helps.
