HD Writer AE 2.0
awolberg
I bought a camera from Panasonic and accidentally scratched the CD with the HD Writer AE 2.0 and will not run the intallation process in my computer.
Does anyone know where can I get a copy of the software? In the Panasonic webpage it says that I should call a 1-800 number but it has been out of service for several days!
tom 2000
On the subject of this software, I have installed it on the laptop but it will not run. The message come up "use a display environment of 1024*768, 16 bits or more".
I am running Windows 7, any ideas?
tom 2000
Yes I went to Display in the Control Panel and altered the settings. Could be in Advanced. It did not seem to make sense at the time, reduced it from 32 bit to 16 bit.
Let me know how you get on.
rosemary
I had the same problem. I was using the right display but had changed the font size (I have poor eye sight). Changing it to default slolved the problem
