HD via VGA?
Discussion in 'Desktop & Laptop Computers Forum' started by Enath, Aug 30, 2007.
  1. Enath
    Enath
    Aug 30, 2007
    2
    Just a small question, i just bought an LE40M87BD screen which is connected to my PC via VGA at the moment (Waiting for my DVI to HDMI cable), and i am wondering if HD playback is possible via VGA.
    I just downloaded 2 movies 1 1080P and 1 720P and i played them with the Haali and CoreAVC codec's.
    The thing is that they look crap, as i could see pixels and the quality was even worst then when i play a normal DVD?
    My resolution is set to 1920 x 1080 and my system specs are as followed :
    - Operating System: Windows XP Professional (5.1, Build 2600) Service Pack 2
    - Processor: AMD Athlon(tm) 64 Processor 3200+, MMX, 3DNow, ~2.1GHz
    - Memory: 1278MB RAM
    - ATI Radeon 9800 Pro 128M
  2. andyr300
    andyr300
    Apr 9, 2006
    2,134
    +104
    yeh,the VGA should be output correctly (aslong as no HDCP in the way) and it should look excellent!
  3. MikeC
    MikeC
    Mar 14, 2001
    225
    Northants,UK
    +10
    HD playback is certainly possible and certainly ordinary mpeg2 HD files should play ok with that spec.
    However, as you have noticed, you need a bit of a upgrade if you want it to play h264 encoded (or VC1) files.
    Judging by other posts from ppl using a similar processor to yours, its not up to the job and also I don't believe the 9800 series offers any sort of acceleration.
    You need to upgrade your processor to at least a 4200 dual core. Regarding the gfx card, your existing card may suffice but I'm not sure.....
    HTH
