HD V+ Box connecting with a Jamo DMR61
kingjohno
I've got a Jamo DMR 61 which I need to connect to a V+ Box.
Currently both are connected, and then to the TV via Scart cables, however if I want Virgins HD content, I need to connect via HDMI.
The Jamo has HDMI out (which I'm not currently using).
I was thinking that the best way could be to connect the V+ Box to the TV through HDMI, and then connect the audio via the red and white audio leads (to the Jamo).
Can anybody help me out as to whether this is the right way to do it? I may also buy a HDMI splitter so I can use the Jamo and V+ box through HD.
Cheers,
M Johnson
kingjohno
Just in case you don't understand what I'm babbling on about!
This is what we have now:
Scart connectors.
This is what I think I need:
HDMI connect to TV.
Audio left and right from V+ to Speaker System .
Chilly Willy
Hi Kingjohno,
To connect V+ box and Jamo system to TV via HDMI - you could use this I am using it to connect V+ box and my Home cinema system.
If you need more HDMI cables try here.
If your Jamo system has an Digital Optical input you could connect the V+ box to it via this cable - this will give you 5.1 sound from any channel outputting the 5.1 signal.
Hope this helps :thumbsup:
Will
