HD TV's.
Discussion in 'Xbox Forums' started by WWFC, Apr 30, 2007.
  1. WWFC
    WWFC
    Well, basically I'm getting a new TV, my parents say 300 quid is the most they will pay. I wan't the best quality of HD I can get. I've looked around but really I don't know what to look for. So if you can point out or give me links to TV's you recommend or what I should look for, i'd be very grateful :smashin:
  2. Pantera6
    Pantera6
    Jul 27, 2006
    353
    +7
    you should really go to the LCD section mate.
    more experienced people willing to help you there.
    but from experience of buying my own. you wont even find a "decent" brand 23" for less than £300. sure you can get other brands. but tbh, i think its better to wait for a bigger budget and get something you know is a good buy rather than a dodgy TV people will question you bought from
  3. Benny06
    Benny06
    Jun 11, 2006
    444
    +9
    Samsung. Get a job, save up some more and get a nice sized one.
  4. wormvortex
    wormvortex
    May 29, 2005
    5,765
    South of Heaven
    +443
    for <£300 your not going to find many, if any good HDTV's
  5. RandomLee
    RandomLee
    Feb 17, 2006
    9,175
    Just check my IP address
    +2,948
    As the others have said, you'll struggle to get a decent HDTV of any size for &#163;300. You should definately try and add some money yourself. Another &#163;200 and you'll find a lot more available.
  6. Dave26
    Dave26
    Dec 15, 2006
    297
    Manchester
    +13
    yeah, lots of really helpful guys in the LCD section.
    I bought a Mirai DTL-527V200 27" for £350, and its great! There's a massive thread about the Mirai's in the LCD section, definitely worth a look :smashin:
    Dave
  7. Mad Johnny
    Mad Johnny
    May 22, 2006
    191
    Worthing
    +5
    As said before save your money as the prices will come down as you save and buy something decent and it will probably last until you leave home!
  8. Blackmage
    Blackmage
    Jul 4, 2005
    525
    +17
  9. almightygoodgod
    almightygoodgod
    Aug 1, 2006
    3,293
    +419
    like the other guys have said, just save up a bit more money and you will open up a much wider range of tvs, much better than settling.
  10. WWFC
    WWFC
    Thanks for the replies everyone, but can someone tell me how I know whether a HD TV is a good or bad one please?
  11. TEVEZ032
    TEVEZ032
    Jan 16, 2006
    2,037
    +95
    can't go wrong with mirai as a budget HD lcd. I have the 32 inch and its ace.
    I suggest you jump over to the LCD section and see what TVs get the best reviews.
    Having owned samsungs and now the mirai, for pure Xbox action, the Mirai is no worse than the best samsung I owned (an M51B). The standard freeview signal is not much different, although the samsung probably edged it on that front.
    I wouldn't listen to the 'brand snobs' if i were you, 'cause you'd be missing out big time....
    g
  12. Scuttlerx
    Scuttlerx
    Feb 15, 2006
    336
    +11
    Is this tv just gonna be for xbox, or you using it for tv aswell....this might affect the advice your given if you were to ask in the lcd forum. Might even get a better deal on a pc monitor style one if its just for xbox
  13. Pantera6
    Pantera6
    Jul 27, 2006
    353
    +7
    well you will get better quality off a panasinic than a mirai
  14. avinitski
    avinitski
    Apr 22, 2005
    3,319
    +216
    get a PC monitor
  15. TEVEZ032
    TEVEZ032
    Jan 16, 2006
    2,037
    +95
    not for 300 quid he won't :boring:
  16. Nivek TT
    Nivek TT
    Feb 27, 2006
    6,565
    Bristol
    +2,132
    You can pick up a 19" wide screen monitor for approx 200 quid. Of course you'll need seperate speakers though.
